Can Someone Please Help....
Or Answer This Question...I Bought Those Three L.E.D Light Thingy That You Hook Up To Your Cigar. Lighter Socket And I Was Wondering If I Could Hook The Wire Up To My HeadLight Wire So When I Turn On My Headlight It Would Light Up Also? So I Wanna Know If It Could Be Done...Or Do I Have To Hook It Up Separate? Like Buying A Switch Then Hooking Up The L.E.D Wire To The Switch?....Please Help....
i dont want to run it from the dash light...cuz ima put the L.E.D under the side skirt...so is there any other way to do it? so im guessing it cant be done by wiring the L.E.D wires to the headlight wires?...
oh ok...i just wanna make sure...cause i dont want to hook it up to the corner light and not come on when i turn on my headlights....another question do i need to hook the wires up to both corner light or it doesnt matter with side i hook it up too?
ok kool...but i have one problem that i dont get....the wire has like a black and white color and then theres a solid black wire...which wire do i hook up to the corner light and which wire i hook up to the ground?....
I use 2 fingers to hold it in place while I push the bezel up and into place, and as soon as I get close enough to smash my fingers and see the plug, I push the dimmer through the hole, snap it into place, then pull back hand out and slide the rest of the way in
honda_motor_co_4life
14
Apr 4, 2007 03:17 PM
osyrhiz
1G CL Problems & Fixes
Mar 13, 2007 01:15 PM
or a search which this kid refuses to do
