can a s2k engine...
hmm, .... the s2000 is a rear wheel drive car with an engine that runs along the car. So the tranny is situated after the engine... I really dont know if ur cl's transaxle would bolt right up to the s2000 engine if u would put it horizontally.
The F20c/F22c is not like the regular F-series motors, you'd have to get an adapter plate to mate it to the stock CL 5speed. Why the hell you'd wanna do that, idk, it comes with a 6speed. Also you'd have to cut your firewall to fit the tranny since its not transversly mounted. You'd also have to get custom engine mounts and whatnot. All in all it's doable, just not as easy as a regular honda swap, and pretty expensive i'd think.
where is....
1 Post
you can't hook it up to the stock tranny even with an adapter. the S2K motor spins the opposite direction (aka forward, lol) You might be able to get it to adapt to a K tranny though, but who knows, this is pretty much uncharted territory.
or you make it rear wheel drive, but there's already a thread about that. lol.
The S2k engine shares little to nothing in common with the F22/f23 found in CLs and late 90s accord.
It's timing chain driven and has direct ignition like the K.
I believe there are people who have transversly mounted the F22c to an rsx tranny in FWD drag cars, i coulda sworn i saw it on h-t before, i gotta go find it.
i like acura
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
THE GRIM
yes it will i thought about doing it but the amount of fab work involve and the money it would cost to do it!{lets just say you could buy a sup up supra or just buy s2000 and turbo it]
but hey its all about being different
but any real power setup will cost money and will spend more money to keep it running and replacing broken parts
good luck on what ever you do
hey i'm just pointing out what YOU said, I just find it ironic that you're actually considering the same thing u were just bashing. maybe it'll make due till u can actually bring ur n22diesel swap to fruition lol.
1 Post
yes, im aware, im not looking for anything more then a 250 whp build. doesnt seem too outrageous on an H. i mean.. 150 whp is just so.... lame. lol having to downshift to 3rd or 4th.. then needing a half mile to pass someone was just so upsetting.
and your right, I did bash it. one day I will pull off that n22 swap though! just gotta find one. lol
1 Post
- 190 PS (187 hp/140 kW) @ 6,800 rpm & 152 ft·lbf (206 N·m) @ 5,500 rpm (BB4 Prelude VTEC, CD6 Accord);
- 200 PS (197 hp/147 kW) @ 7,000 rpm & 156 ft·lbf (212 N·m) @ 5,250 rpm (BB1/4/6 Prelude SiR's);
- 200 PS (197 hp/147 kW) @ 6,800 rpm & 161 ft·lbf (218 N·m) @ 5,500 rpm;
- 220 PS (217 hp/162 kW) @ 7,200 rpm & 163 ft·lbf (221 N·m) @ 6,500 rpm (Accord Euro-R, 92+ Prelude Type-S & 97+ Prelude SiR SpecS);
- H22A1 190 PS (187 hp/140 kW) @ 6,800 rpm & 158 ft·lbf (214 N·m) @ 5,500 rpm ('92-'96 USDM Prelude VTEC)
with an average h22 with the proper bolt ons and a tune, 170hp isn't hard to reach. i've seen a few guys on h-t w/ I/h/e and a vafc or neptune tune make 170 whp.
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
