Camber kit
Camber kit
Are all the kits the same? I really want to get one but don't know what kind and exactly what I am looking for. I know that ingalls make a kit and thats cool and all but what about this degree stuff. Help me out someone
Just make sure you get rubber bushings instead of polyurethane. The squeaking of the polyurethane is unbearable for a nice ride. I made that mistake with my integra and I have to spray w-d 40 on them once a week just to keep the noise down.
Oh yeah as far as degrees of adjustability get the ones with the most adustability because if you go low you will need more degrees. I used ingalls and I have no complaints besides the noise from the bushings which are attached to the kit; polyurathane as i mentioned before.
How bout Evotion or Dropzone camber kits? Are they just as reliable? Im waitin for my Neuspeed Sport Springs to come in, got a 97 3.0....i was pretty clueless as to what camber kit i was supposed to get, but now at least i know to go with rubber. How does the different degrees and anglings work with the kit? Does it depend on the springs, or is there more to it than that? Cuz im not completely sure which kit i should be getting with my setup. Any help would be appreciated.
Leon I need picks and specs oh and a price. As for the help do they make kit specificly for our cars or do you have to get the ones for the accord. I have a 98 3.0 and my springs are new speed close to 2" bot exactly sure. I want the best and no noise and no more rub my tires are getting eat up by the rubbing. good thing I don't like the tires on the rims I got.
teh Senior Instigator
why would it need to be specifically for our car, we are IDENTICAL to the accord
For the front try the ball joint camber kits from Ingals (new) or SPC. The other ones just squeek no matter what you do... even the rubber bushing ones squeek with time. I had my Ingals rebonded after a year (sent in for warranty) and they squeeked again after a month.
If you do go with the ball joint camber kit be aware that the CL's have two different runs of ball joint sizes (I think it had to do with the ball joint recall). I originally ordered the one listed for the CL's and found out while installing them that they were too big... I called SPC and found that I needed the smaller '95-'97 Accord model. Also, some shops are resilent in changing ball joints... you should find a shop that will change them before you buy them.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
