Camber Kit ?
Old Jun 19, 2004 | 02:06 AM
roddymerritt's Avatar
RODDYS
Camber kit
I need camber kits and pricing please
Oh pics or links with pics would help too
Old Jun 19, 2004 | 02:11 AM
CLver's Avatar
Go to suspensionmax.com
The ingalls front and rear kit is 110. (Rear is composed of bolts with spacers, NOT entire trailing arm)
This kit will allow you to adjust from camber 3+ degress in the from and 1.5+ degrees in the back..
Also ebay as always.
Old Jun 19, 2004 | 02:15 AM
RODDYS
ok I am dumb when it comes to this stuff but if my stock struts go out will that cause my wheels to tuck or should I go ahead and get a camber kit
Old Jun 19, 2004 | 03:06 AM
baka_t's Avatar
The movement has started
Struts have nothing to do with making camber worse unless you lower the perch on the strut itself.
Old Jun 19, 2004 | 09:13 AM
RODDYS
so if the struts go out it won't make the car sit lower? How much should a camber kit for both front a rear cost me
Old Jun 19, 2004 | 01:34 PM
CLver's Avatar
Front and Rear is 110+15 shipping
Old Jun 20, 2004 | 12:01 AM
RODDYS
can you hook me up with a link
Old Jun 20, 2004 | 01:29 AM
baka_t's Avatar
If you drive turns and whip turns alot, i'd stay away from the bolt, washer correction in the rear. You want to get the adj trailing arm.
Old Jun 20, 2004 | 01:04 PM
RODDYS
so where can I find that cause I do sometimes drive really agressive through sharp turns
Old Jun 21, 2004 | 08:57 AM
rad_cl_racer's Avatar
Fawkin Gruvin
just admit that you drive that shit like you stole it!! I do !!
Old Jun 22, 2004 | 12:23 AM
GhEnGisTaHN's Avatar
http://216.242.145.9//shop//product.phtml?p=66
i found these cambers do the brand matter.. or are they all the same??? im any help will be appreciated cuz im wondering if im being frugal
Old Jun 22, 2004 | 10:54 AM
RODDYS
if those work I will get them some one tell me if these are any good
Old Jun 22, 2004 | 03:25 PM
ib_jimmy's Avatar
Ingall camber kit is the best for our car.
Old Jun 22, 2004 | 03:29 PM
VXCL's Avatar
AWD Torque Monster
just go to home depot and get your own bolts and washers. driving hard will not effect anything as long as you use a longer bolt. it aint comming out. u need 2 m10x1.35 60mm bolts. i used 2 galvanized washers about 2mm thick to get mine to specs. im dropped bout 2" in the rear.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
