Broken catalytic converter?
Old Aug 11, 2004 | 02:03 AM
krazy99cl's Avatar
O.G.
Hey guys.....first of all thanks for looking.....but i gotta bad problem.....
i was pimping along with my car and it was sorta dark....i ran into a HARD ditch
(didnt hear anything) and parked....the next thing i knew...everytime i
rev about 2 1/2 rpm it made a rattling noise...went under the car and still rattled....
took it too Muffler Tech in SAC and said i gotta get CAT CONVERTER at the dealer....~$ 435.08 SHIT.
DO YOU THINK I SHOULD TRUST THEM....AND GET IT....DOES ANYONE KNOW WHERE I
CAN GET ONE LITTLE LESS????? CHECKED ONLINE BUT I SOMEWHAT DONT TRUST THEM...
Old Aug 11, 2004 | 02:15 AM
white3.0's Avatar
try a pick and pull
Old Aug 11, 2004 | 02:17 AM
white3.0's Avatar
or you could jack your shit up take a look tighten/patch up any kinda dmg?
Old Aug 11, 2004 | 02:30 AM
krazy99cl's Avatar
O.G.
THEY SAID THAT IT WAS CRACKED FROM INSIDE......I HAVE NO IDEA..
Old Aug 11, 2004 | 02:32 AM
krazy99cl's Avatar
O.G.
My Check Light Went On....but My Stupid Self Thought It Was Like A Oil Change Or Something And Reset It And Muffler Tech Couldnt Read It....!
Old Aug 11, 2004 | 02:33 AM
white3.0's Avatar
mabe it broke one of the sensors off?
Old Aug 11, 2004 | 09:58 AM
xrunner86x's Avatar
A-CL Totaled Member
Acuraautomotiveparts.org has the cat for 374 + ship for the 2.3. What do you have? Your cheapest route that will pass emissions would be to buy a Carsound cat and have it fitted by an exhaust shop.
Old Aug 11, 2004 | 11:09 AM
powderman's Avatar
i'm too lazy to earch for it, but last month sometime someone had a similar question, and a guy left a link that had like 4 converters, all under $100. might need to do a little retrofitting, but its better than being raped by the dealer
-mike
Old Aug 11, 2004 | 01:19 PM
wilp99's Avatar
acura should cover it under the extended warranty on the emissions parts. egr valve, o2 sensors and almost everything exhaust. ask them first.
Old Aug 11, 2004 | 01:20 PM
wilp99's Avatar
i think it goes to like 150k miles.
Old Aug 11, 2004 | 06:10 PM
dep3che's Avatar
Die Trying
If its' a rattling sound and its right near the cat.. yeah dood. you're gonna have to replace that FAST, there is a beehive looking thing inside that will break off with time. I had the same thing happen to me, but luckly I got that taken care of before anything bad happend. Try your local motorsports shop and ask for a cat replacement. SRD here in Phoneix got me a Hi-Flow cat installed and everything for 200 flat, and a very good job and could tell that I really needed a new cat. Thats my advice to you man.
Old Aug 12, 2004 | 12:21 AM
DaInFaMMuS1's Avatar
y dont u just get a catco high flow cat...thas what i did when mine broke...the cost of purchasing it and installing it was $248 i believe alot less than that factory shit and itsa bit of an upgrade
Old Aug 12, 2004 | 12:44 AM
krazy99cl's Avatar
O.G.
yeah i'll have to look into that....thanks
Old Aug 12, 2004 | 07:24 AM
wilp99's Avatar
or take the old one off and beat the hell out of it with a hammer, to get all the catylist. "bee hive looking stuff" inside out and u got a high flow cat.
Old Aug 12, 2004 | 08:10 AM
CLdude23's Avatar
or you could jack it up and check to see if it is just the heat shield that is rattling. I know on civics and accords.....eventually the heatshield becomes loose and rattles at a certain rpm. Happened to my g/f's civic and i tore it off in about 5 seconds with a hammer. No harm done , it is only a heat shield.
check that out first. Then check to see any broken sensors.
As for the catylitic converter.......you can get the catco one for like $70 at summitracing.com
dainmezron
Oct 16, 2015 06:56 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Rcelestino93
Sep 23, 2015 10:01 PM
