brembo rotors...?
Old Sep 13, 2003 | 11:35 PM
acuradan69's Avatar
brembo rotors...?
I just received my cross-drilled/slotted rotors for my 98 acura 2.3CL
the front rotors look like they are "2-ply double layer" with 6 slots and 6 holes between each slot.(front is heavier than the rear)
the rear rotors look like they are "one ply single layer" with 6 slots and 3 holes between each slot.
is this how its supposed to be?
just worried cause on the invoice it says brembo rotor (90-97 accord 4cul, 97-00 CL 2.2L)
for the fronts
and
brembo rotor (97-00CL. 90-99 accord 4cyl, 95-97 accord 6cyl)
for the rear
Old Sep 14, 2003 | 03:09 PM
dulux's Avatar
If you look at the rotors on your car now, they are "2-ply" up front and "1-ply" in the rear so it kinda makes sense that the new rotors would follow the pattern or else you might need different calipers.
Old Sep 14, 2003 | 03:52 PM
acuradan69's Avatar
yup... just checked it today...
Old Sep 14, 2003 | 03:54 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
where did you get your rotors from? mine are warped and need to be replaced
Old Sep 14, 2003 | 04:38 PM
acuradan69's Avatar
islandmotorsports.com
talked them down to
380 shipped
4 rotors drilled/slotted and silver plated
with 4 aem pads
Old Sep 14, 2003 | 06:48 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Front rotors are "vented"; hence the "2-ply" look (and larger diameter).
Our rear rotors are no "vented"; hence the "single-ply" look (and smaller diameter).
polish_pat
Sep 30, 2015 12:22 PM
Lucrativesoldier
Sep 28, 2015 03:47 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
TL-GIXXER
Sep 18, 2015 10:25 PM
jmoney2001
Sep 11, 2015 12:07 PM
