Brake Rotor off hub??
Hello, long time since i been on here. Cars been through a lot. I have a 97 cl 2.2 which was wrecked about 6-7 months ago messed up the front end pretty badly. Ever since then it through me off track with maintence and keeping the car up the brakes got so bad the front pad slipped and jammed up. Anyway new caliper,bracket, pads and rotors going on today however I cant seem to get the rotor off the hub. Tips please?
here is a couple more threads that you may want to read as well
https://acurazine.com/forums/1g-cl-diy-faq-74/diy-easy-hub-rotor-removal-without-press-693210/
https://acurazine.com/forums/1g-cl-diy-faq-74/97-3-0cl-brake-rotors-how-end-all-rumors-493677/
Totally Different Way?
Ok, after sitting down and thinking a while. I just knocked the spindle? or whatever goes through the rotor back enough to get to the four nuts behind it with a 12mm offset wrench. then i put a pully and pushed it through the back. after that the rotor came off i changed it easily and put it all back on. Now the question is, do i need to bleed the breaks and how thoroughly
well two of the bolts that go into the back of the rotor were loose and the heads got eaten up so i ordered them they were the wrong ones so i need to order from honda im guessing.. are the the 10x1.00 thread bolts ? how do i tell them that the threads dont run all the way thru the bolt ? what is that called someone please help so i can get the car back on the road!
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
