brake problem // suspension problem // i dun know
every time i go over 40 and press the brakes my steering handle shakes !! i don't know what the problem is !
no thier not warped with anything. just regular rotars maybe something on the back is warped up but when i see it thru the rims is not warped with anything from what i can see.
A-CL Post Whore w/N2O
Warped, meaning that the surface of the rotor (or the entire rotor itself) is not flush. The there are high and low spots on the surface of the rotor, then when the pads pass over it, it causes the steering wheel to shimmy and shake.
You may not be able to visually tell if a rotor is warped. However, if the rotor is machined (shaved), the rotor's surface becomes flush or "true".
i have warped rotors...cuz i drive to fast and brake faster...i got em shaved once and man it was some smoooooth braking after that...for about 3 days and then they were back to normal...Ive learned to live with the shaking wheel now. If i dont feel the steering wheel shake then i get worried
http://www.rsversion.com/list.asp?Ac...&Keyword=rotor
do they come in BLUE only ??? or do they have other colors ?
mada51589
05-03-2022 08:54 PM
