brake bias ?s
brake bias ?s
is there a way to change the bias at all? ive searched for about an hour and i cant come up with anythin. my rear rotors stay rusty no matter how much i drive. today i cruised for about an hour with a lotta stop and go and i got out and felt the rear rotors and they were still cold. any advice? btw my car is a 98 CL 3.0
How long have you had the car? Have you recently done a brake job?
I dont know if it is a matter or bias, rather a caliper failure. If the caliper is not allowed to float on the rotor and has seized, the brakes will not engage.
All brakes should work all of the time regardless of use.
If it is one of the rear brakes it could be seized open. If it is both I would check the hose as best as possible from the master cylinder. Rubber hoses are subject to corrosion and swelling sometimes.
I would get that sorted out quick cause trying to stop these heavy beasts on two brakes is kind of scary IMO.
probably the caliper sliders are seized, they were on my car when i bought it, its an easy fix actually. Depending on where you live right now, its very doable by yourself. Or bring the car in a garage that has a torche, and they will be able to unseize the slider. But then you have to remove by sanding or using some rust remover liquide to remove all the rust, and lube the sliders very well, and maybe replace the rubber bushings, which are the reason the sliders got seized in the first place probably.
rear brakes dont get much play in a FWD car.
to make sure everything is in order, check your calipers for seizure or failure...quite common problem, i've replaced a rear one on both my Prelude and the CL.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
