black headlight housing
Old Feb 7, 2003 | 01:31 AM
lowboy's Avatar
i think it was 1stgencl that said he got black headlight housings for $10 i want them how did u do it for $10
Old Feb 7, 2003 | 02:37 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
$10 your tripping. thats about how much it costs to do it yourself man. do a search next time and youll find something on this matter
Old Feb 7, 2003 | 02:41 AM
AcUrALiTy's Avatar
10$! ur joking, prolly for the paint lol
Old Feb 7, 2003 | 07:20 AM
1StGenCL's Avatar
958 & 991
Yeah i did them for $10 bucks or so. I dont think its that far off, 4 bucks a can for paint (1 primer, 1 black=$8) plus 2 bucks for silicon gives me 10 but yes i did them myself, i was the first CL to have them in fact
Old Feb 7, 2003 | 03:30 PM
lowboy's Avatar
how did u do it
Old Feb 7, 2003 | 04:41 PM
showtz's Avatar
06 CGP TSX NAVI
When I have some time to black mine out I will make a Step by Step instruction guide with pics; unless there is already one out there? I think this would help answer alot of questions. Until then you have to use the search button and look for this much discussed topic. I'm sure I will even have some questions when I start taking mine apart.
Old Feb 8, 2003 | 07:29 AM
Zerostatic's Avatar
100% Dominicano
That would be awesome, and not to mention much appreciated.
Old Feb 8, 2003 | 09:47 AM
1StGenCL's Avatar
958 & 991
Heres my quick write up
You will need:
-High temp Silicon (avail. at Wal-Mart & hardware stores, pref clear)
-oven & cookie sheet or heat gun (I didnt use the gun but...)
-flat head and philips screwdriver
-primer
-flat black high temp paint (i used flat but its up to you)
-A good days time to let them cure
1. The first thing you need to do is remove the bumper. I didnt do this so im not sure how to go about it but trust me its easier than ripping the fenders apart trying to get the freaking screws under the light.
2. Then i took the headlights and removed the rubber piece around the corner and the tubes on the back of them and put them in a unpreheated oven (that was set to 200 degrees) on a cookie sheet, I let them "cook" for around 3 minutes and pulled them out to see if the factory silicon was sticky.
3. I slowly (i cant stress Slowly enough othewise you will break tabs) took a flat head screw driver and pryed the lights apart. If the glue started to harden i put it back in the oven for a minute or two. Make sure you watch the lights cause you do not want them to melt, obviously
4. After you get the housings apart but the lens aside so it will stay clean. You dont want finger prints or dirt inside your housings.
5. You should see 2 or 3 screws that hold a silver part in the lens, unscrew it and pop the clear corner lens off.
6. Next mask the corner part of (the corner that holds the 194 bulb). If you want the all black look you can paint the corner too but you wont have a light there anymore (well it cant be too bright). I personally dont like the look but a few members have done it.
7. Spray light, thin coats of primer on to cover the chrome up (took around 3 i believe)
8. Let it dry completely and then spray 3-4 coats of black on.
9. I let mine dry over night and then peeled the tape off. If you peel it too soon you will take the paint too.
10. Make sure you are happy with the lights and then put the housing back in the oven for a couple minutes to soften the glue (just the housing part with the reflectors, not front lens or the part you just painted).
11. Pull the housings out and screw the black part in making sure you put that corner lens back on.
12. Put a bead of silicon around the headlight where the factory stuff is
13. Press the light back together and make sure all the clips are secure. I have heard it is best if you use a clamp to hold it tight so you may want to try that too
14. This part is optional but i didnt want to pull the lights out again because of fog so i put an extra bead of silicon around the headlight seal. It doesnt look great but you cant see it and they dont fog.
15. Reinstall
Its been awhile since i did this so i dont remember exactly how many screws or coats of paint but you will figure it out and im pretty sure im right about it PM or AIM me at Pat353 if you have any other questions Good luck
Old Feb 8, 2003 | 12:46 PM
dulux's Avatar
does anybody have a closeup picture of what the black light housing looks like? (after completion)
Old Feb 8, 2003 | 04:00 PM
CLTECH's Avatar
Honda Technician
as soon as i get my new digital camera in (Sony DSC-F717 ) i'll take as many pictures as you want. till that day, someone else will have to....sorry
Old Feb 8, 2003 | 04:53 PM
lowboy's Avatar
thanks alot
Old Feb 8, 2003 | 07:07 PM
1StGenCL's Avatar
958 & 991
Geez, first you want instructions now you want pics too :P Here is a distance shot to give you an impression of the "whole" look and then there is a closer shot but they have the HIDs on. The headlight has a horrible film in that pic so the light reflects off the housing but oh well, i have cleaned it up
Old Feb 8, 2003 | 08:20 PM
rEmixnZZa's Avatar
is there such thing as white housing?
or does it come white? lol
Old Feb 8, 2003 | 08:32 PM
ACURACLZX6R's Avatar
4th Gear
Is there someone that sells the black headlight housings already done. I'm not to good at doing things like that I'll end up having to buy all new head lights.
Old Feb 9, 2003 | 04:50 AM
VXCL's Avatar
AWD Torque Monster
Old Feb 9, 2003 | 04:56 AM
VXCL's Avatar
AWD Torque Monster
heh 1stgen cl when i post new pics of my car it will be identical to your front end cept for the hid projectors in my housings. i even bought a 99 grill for my 97. so fresh and so clean! i might paint behid the "A" though.
TLrascal
Aug 3, 2018 11:00 PM
pistacio
Sep 26, 2015 09:45 AM
JnC
Sep 11, 2015 06:06 AM
voigt
Sep 2, 2015 10:44 PM
