Best place to buy brake pads?
Ahhhhhhhh
Got the squeeks for a few weeks now it's definitely time for some new ones - planning on installing these on our own. What's a good place to buy them? Also is there a mechanics guide for the job?
Bagel Bomber
This is pretty easy, front or back? People will likely tell you to spend loads of money on some aftermarket ceramic that cost about $100 but unless you are driving your car like a 16 year old with a fresh license, you'll be fine going to the local parts store and picking up whatever ceramic pads they have there and some grease for the back of them so they dont squeel.
If you are not going with performance pads, I would definitely recomend oem honda brake pads. They only cost about $40-50. In my experience these are the only pads that do not squeak. I have had horrible experiences with autozone nd pepboys brand brake pads. As for the job, make sure to have a can of brake parts cleaner, torque wrench, caliper pin grease(to grease caliper pin and also back of pad that makes contact with caliper), c-clamp to compress the piston.
'99 2.3 CL
as for the rotors, I again recommend Honda rotors only because I have seen them go 60,000+ mi. without warping. Cannot say I've had the same luck with aftermarket stuff.
less n00bin more g00glin
anti-seize on the back of the pads will reduce any squealing later on too. Dont need much, and dont get any on pads or rotors cause you will want to kill yourself.
Ahhhhhhhh
Ahhhhhhhh
Should I be replacing front and back at the same time? The sound only comes from the front.
take your wheel off, place the lugs back on moderately hand tight. With a dial indicator measure the lateral run out in thousands of an inch "0.001 at the most outter edge of the rotor. Anything more then 5thou replace. Do not bother to resurface, it is a waste of money and time, just get new.
Bagel Bomber
Pop off the rear wheel and have a look at the thickness, since you already have the jack out.
On my 98 3.0 the piston has to be "screwed" back into the caliper. The front, piston is compressed back in with a larger Cclamp.
As far as rotors, i put these on:
http://shop.advanceautoparts.com/pro...pe=221&PTSet=A
and have been loving them. I still think that price is a mistake. If the warp in the next two years return them. Can't beat that. You'll know if you need to replace or have your current rotors resurfaced if you get a viberations when you brake. At least in my area $18 a rotors was cheaper than resurfacing.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
ebay
Former Sponsor
If you just need OE replacement regular ceramic pads try NAPA or Autozone. If you want some performance pads check out our web store: http://store.excelerateperformance.com and look for Hawk ceramics.
Ahhhhhhhh
Sounds like I am headed to Kragen to pick up front brake pads. Is there a DIY or manual scan on here for the install?
Thanks to all who have replied.
If you've changed pads in a vehicle before, it's no different. I believe there's two bolts that hold the caliper on. Unbolt, remove the pads. Use a C-Clamp to push the piston back in. Set in the new pads, and bolt the caliper back on.
not to hijack the thread from the op
give suggestion i have slotted and drilled brake rotors
that belong to the last owner i wanna keep them on my
car, though soon i might have to replace should i get them
resurface or just buy new rotor.
im guessing its all up to me but what you think anyway.
thanks
mike.
thanks
mike.
thanks
mike.
thanks
mike.
(Mid-Atlantic)
(Mid-Atlantic)
thanks
mike.
thanks
mike.
(Mid-Atlantic)
(Mid-Atlantic)
You can try, most shops won't even try for you. They warp easily as it is
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
