back seats
A-CL Post Whore w/N2O
Check between the seat bottoms and the seat backs. There are one or 2 bolts there. When you try to remove the seat bottoms, sit on the seat and reach down between your feet. Right where the seat bottom touches the carpet, you should find a metal tab. Gently lift up on the seat bottom, and you'll feel a metal tab. Grasp the tab with a pair of needle-nose pliers, and pull up and towards the front of the car. There's a tab on each side of the seat bottom (driver's side and passenger's side). Push the seatbelts through the holes in the seat bottoms, and the the seat bottom should come out.
If there are more bolts to remove the seat back, you should now have a better view of them.
i want a bimmer =(
yeah...just take your time and dont get frustrated.
we had to take them out when we installed my coilovers and they were a bitch to get out...
good luck
good luck
i want a bimmer =(
Originally posted by ApocalypseCL
hey katie where the hell have you been i havent seen you posting in a while!
i have been whoring it up in the Ramblings section alot...it's funny as hell over there.
Mazda3 and Honda Civic in
Originally posted by Katies99CL
haha...awe i feel loved!!
I spend alot of my time over there.
I tool my seats out along time ago as well, its a little fustrating
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Originally posted by ACURA-C
ghander, where is your rear seat wall with the pass through opening. I have a 97 is that why?
Mine is the same, there is a big metal cage behind the rear seat that you can take out.
Still trolling
He probably cut it out?
Oh, and yes, you will need to look between the back and bottom of the rear seat to remove the one 10mm bolt holding the bottom of the rear seat at the back. Then there are two metal tabs where the bottom portion of the rear seat meets the carpet:
T = Tabs in the front
R = bolt at the Rear
|----T--------------R-----T----|
Lift the seat up a bit to reveal them, grab it with needle nose, and pull the tab out a bit while pulling the front of that seat up. It releases the clip holding it to the floor.
You will need to carefully fish the seat belts through the openings to get the seat the rest of the way out (it sucks).
THen you will see the remaining 3 bolts holding the upper portion of the back seat in. Remove those, and lift the entire upper portion up towards the rear glass. There are 3 hooks at the top of the upper portion that slide down into the rear deck to keep it in at the top. By lifting you are sliding them out of the holes.3
H = Hooks on the top
b = bolts at the bottom
|----H-----------H------------H----|
|--b---------b-------------------b--|
Originally posted by ghander
the back cage unbolts.
Originally posted by ib_jimmy
dont need to take the back seat off to put in coil-over or springs.
as far as weight reduction, I'd say maybe 30 lbs. That rear plate is pretty heavy. I took it out because I was planning on making a straight through deck and carpeting it to match so I could mount my nitrous bottles in the back seat. After I got everything cut out and ready to mount I changed my mind before I started carpeting
i want a bimmer =(
Originally posted by chrisbpickering
A hell of a lot easier. You would speed 6x the time loosening and tightening the bolts buy not taking out the seats.
I dont even use a spring compressor to install new springs. i just put a floor jack under the suspension and take out the center nut. lower the jack and unbolt the upper arm control. put some weight on the suspension and pull the spring out.
rockyboy
08-04-2024 10:35 AM
