Attn: KikAzCL97
Ya I got mine out and it sounds pretty cool. The box all the way at the bottom is held by 2 10mm bolts. But you only have to udo the bolt in back. If you take out the bottom 2 screws that hold the plastic liner in place and pull that back a little and look in you should be able to see a bolt attached to the frame of the car take that out. Once that is out wiggle the box up and down and pull it towards the back of the car at the same time. If you need more help I might be able to post some pics tomorrow night.
