Anyone install dome tweeters in their mirror sails?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If so, please post pics. How much depth/clearance was there? Trying to figure out if I can mount my tweeters there. The mirror sails are the black plastic trims that covers the mirror wires for someone that doesn't know what i mean. I've seen people's pics mounting them in the stock location and in the door itself, but haven't seen any mounted in the mirror sails. Anyone done it and have pics?
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by starboy2nv
if your doing it for a better sound, custom kick panels will project a better sound imo...
Nom Nom Nom Nom
Mount them on the door somewhere. To get the best sound out of them they are supposed to be within 12" of the woofer.
I dont think the mirror sails are deep enough to mount them flush. I dont think they would look great if they were not mounted flush.
trini to de bone !
don't mount them flush....break out the fiberglass and resin and make them look like the Civic Sir (or US EX) ones, and have them angled and stuff
how handsome I am
what the hell kinda setup you have? lol
my mb quart fits in perfectly
how much did you spend on em and which ones? I want to upgrade my tweets before I throw down on a small woofer... already have 6x9's and 6 1/2's...
The new ride
Originally Posted by agranado
mb quart up front where stock tweeters go, correct?
did you get coaxial speakers? you're supposed to get component speakers, a set of 2 woofers, 2 tweeters, and 2 crossovers.. i was just wondering what you did/planned to do, i dont know if anything bad can result from using coaxials and tweeters up front, as long as you have crossovers, deinitely have crossovers, you dont want the full range of signals goin to your new tweeters, it just might end up being more expensive in the end instead of buying a set, oh and you'll have to run new wiring to the tweeters, have fun, sorry for rambling lol
The new ride
Originally Posted by HyDrOpOnIkToKa
i custom made mine in the original tweeter enclosure, juts used a dremel, ive had them for awhile , will post pics l8r
First EVER K24 Turbo CL
im not sure on the model # i think its qs something.... ill have to check the crossover for you.. for the front component it was like 4 and change... and the rears was like 2-300....
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Mulk
blackack what size are your tweeters you're trying to fit in?
(Mid-Atlantic)
(Mid-Atlantic)
1" Silk Dome Tweeter, they're big mothas
The new ride
I mounted 1" alpine tweeters, I have the 6.5" type r component system. I remember exactly what i did now, there was a metal bracket that went across the bottom of the stock tweeter, two screws held it onto the bottom of the plastic/fabric part that sits in the dash, and one screw goes into the center of the bottom of the tweeter. the holes for the 2 screws outside the tweeter had to be shortened, I just used pliers to break half of the holes away, then used longer screws becasue the original ones werent long enough, the tweeter was deeper so it moves the bracket a bit further away from the plastic grille part. the screw holes had to be cut because the tweeter was too wide to fit in between them, and the screw in the center of the stock tweeter with the bracket fit into the hole on the bottom of the alpine tweeter, I'll take some pics in a little bit for you, hope that helped.
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Thanks nippon, I looked at those pics b4 I posted this, cuz i thought i remembered you putting them in the mirror sails but I realized i was wrong. I don't wanna put them in the door there, cuz like someone mentiond in your thread, rain water drips right there I am interested for anyone that can help me or give me pointers on either the mirror sills or maybe the stock location if you can tell me how to mod it
WEAKSAUCE !!!
tweeter location
i have the same problem right now... i hooked up the stock tweeter into my cross over b'cuz i couldn't fit my aftermarket tweeter in that location. from my understanding it would be better to relocated the tweeter and have them in the plastic where the mirror is or mount them into your door panel = ( right now i have a wire coming down from the stock tweeter into the door which leads to the crossover... it looks kinda of sloppy so i am going to get it mounted in the mirror even though it would be flush mounted....
the ALPINES:
6.5 with the 1in silk tweeter alpine type r's how are they by the way im actually going to ge those????
the ALPINES:
(Mid-Atlantic)
(Mid-Atlantic)
i cant wait until i get a 4 channel amp and they'll sound 10x better
Sorry for the blurry picture, I just took it tonight... right now.
I basically just cut a hole with a dremel and literally dropped my Focal Tweeter into the stock cover thingy since the Focal tweeter has a lip to catch it from falling through.
The new ride
alright blackack, here you go, this is the driver side tweeter, sorry its blurry:
Screws marked A hold the bracket to the speaker grill, and the screw marked B holds the tweeter to the bracket.
The red box shows where the A screw goes into the hole, and you can clearly see how I had to break some of it away, I had to do this with both screw holes.
The new ride
The new ride
Originally Posted by Lunchbox
Thanks Mulk. I got the 6 1/2 components and a pair of 6x9's for 255 shipped.
oh yeah do you have a head unit yet? if you have bose, you cant hook up the speakers to the bose system, if you need a head unit, i have one for sale, PM me if interested.
Scissor Me Timbers!!
No I don't have the BOSE. thank god. I have a sony in dash screen right now but I'll be selling that on ebay soon and getting another. What head unit do you have?
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by penaduny
i have a set of components in kick panels.. then a second set of components in the doors, and the tweeters for that set is in the stock spot in the dash. it hurts.
(Mid-Atlantic)
(Mid-Atlantic)
black did you see my pic of the tweeter and figure out what im talking about?
all u bastages and your nice stereos. i have 2 stock bose tweeters, 2 stock bose 6 1/2s 1 stock bose 6x9, 2 kicker comp 12's and a matching kicker amp all running through stock stereo.
