any h22 swaps with check engine?
LA`s Top CL
hey any of you guys that have the swap get check engine light sometimes? iono but im runnin obd1......... str8 pipeing is what im thinkin the problem is what yall think??
Big Block DOHC Type-R
Duce, if your car is throwing check engine, look up under the glovebox. There should be a blue plug with nothing pluged into it. Take a small piece of wire and bend it like a U shape. The plug will have two pin holes. Plug one end of the wire in one pin hole and the other end of the wire into the other pinhole. This will cause a loop and display your check engine. Look up the number that the check engine light flashes and that will tell you what the problem is according to the codes.
DOOKS of hazard!!!!
its a trick! dont do it! that makes the self destruct in five seconds! hahaha, hope you get it figured out man....im doin an h22 soon myself! hope im trouble free.........
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
