any difference between 96-97 and 98-99?
#81
its because our fuel gauge is mechanical and not digital. ever notice when ou park on a hill you have a different amount of gas then when your flat? its a mechanical bobber, much like one from a toilet that tells the gauge how much gas is in the tank. if you have a 1/4 tank and park facing uphill on a relativley steep hill, chances are your going to have a gas light on when you get in the car.
These bobber type gauges wear out quite often too, I've changed out a few before, usually some of the resistance wire breaks. Which brings up a different thought, technically if you consistently fill up all the way and not fill till almost empty, this simple gauge will wear less since it doesn't vary a small degree up and down and instead spends equal times at all heights of the gauge.
#82
1 Post
Yeah, more often then not, the bobber gains density over time from slowly absorbing gas, so it starts moving less. also, the arm that holds it can corrode and rust, along with the rubber lubed pieces on the arm. just hinders the movement
joflewbyu2
10-08-2015 11:16 AM
