any 2.xers install a throttle body spacer?
i jus installed an obx one and i dont get that bov sound like the 3.0ers say they have. all i get is a nice whistle that kinda sounds like a spooling turbo.
not sure if its cuz i have a 2.x or cuz i installed it wrong some how.
Also since i have an f23 i ordered the 98-02 accord tb spacer since its the same engine if any other 2.3's were interested. the 2.2's should get the 94-97 one. im not even sure if the tb's are any different but whatever.
theres soemthing on ebay with a speaker and connected to ur speedometer...it sense when ur car is accelerating and make a spooling sound....when ur car shift it put out a BOV sound. that would be a picture setup for you. not sure how much hp its gonna give you.
Originally Posted by KLepTo
did you want a BOV sound? even though you arent boosted?
and as for gains the throttle response seems a little better and the rpms climb a little faster but i mean all i got is an intake to go with it so nothing significant.
Originally Posted by Palayah8ta
so including installation time, and difficulty, and the gains its giving u? Is it worth your $50 bux?
I put a helix TB spacer in my 2.2 on tuesday and I love it. It makes a cool spooling noise during moderate throttle above 2500 rpms, but not a very noticable BOV noise if any. Like you said, theres minimal gains but it seemed to smooth out my power band a little.
That turbo noise makes me soo happy However, removing those two studs from the TB didnt make me happy
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by suremang
yea i destroyed those 2 studs in the process of removing them haha.
The studs were just a pain in the ass because I was using a big ass vice grip wrench in a pretty tight space, so i had to clamp-short turn-unclamp repeat atleast 50 times.... i dont think itll be bad on your 3.0, but takin of the IM might suck
http://cgi.ebay.com/ebaymotors/OBX-T...spagenameZWDVW
jus search obx throttle body spacer accord theres a buncha them
are you guys kidding? just do the double nut method (i forget the technical term). put 2 nuts on the stud one in reverse and one normal, tighten them together, then just use the bottom nut to wrench off the stud...
btw i thought the lock nut trick was one of those common mechanic tricks lol....learned it from my dad. lol
Have a friend w/ a 6th gen v6 accord with the spacers;
From my understanding gains are minimal @ best, 1-2hp and 1mpg after installing the spacer (Helix or whatever); also there isn't a BOV sound @ all, just the winding air sound. <--- synonomous to a turbo spooling up.
Originally Posted by bizob_cl
actually, with the combo of a lightened flywheel header intake and no cat i noticed a difference in throttle response.... plus that cool whistle.
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 972xghost
hmmm, i didnt see anything left from OBX for the 94-97, im sure the 98-02 will fit so ill get that. that is unless i look at the Helix.
cycdaniel
12-17-2019 11:58 AM
elietania
4G TL Problems & Fixes
09-05-2015 07:52 AM
