Antifreeze Leaking?????????
HOOK EM HORNS
antifreeze is leaking around my water pump on my '99 2.3
has anyone had to replace the water pump or hoses associated with it? any experiences? anyone know how to tell if its failed?
i was also wondering where to get a manual for my car-- i need a 94-97 accord book right?
i just ordered KYB AGX struts and a WW front lip
and i thought i might order a new water pump as well
cardiff blue '99 2.3 5spd
-H&R springs
-Injen CAI
-Ingalls camber kit
-port and polished by Jotech racing
-painted WW lip on order
-KYB AGX struts on order
H22a from '00 SH coming this summer
-H&R springs
-Injen CAI
-Ingalls camber kit
HOOK EM HORNS
im sure its not expensive
did you replace it for normal maintenance? or because it failed?
i am replacing my timing belt when i install my struts and lip
HOOK EM HORNS
hey jimmy!
ya i get off at 9:30 actually![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
my temp gauge is normal,, but that was definately an abnormal amount of antifreeze
i think i will flush it out and let my car run for awhile and see if anymore is leaking
do haynes or chilton make a book for a '99 2.3?
Mazda3 and Honda Civic in
Maintenance....
Pass the dutchie!
damn i have noticed some spots on my driveway and was going to the dealership tomarrow morning, cuold my problem be antifreeze also, it bitter winter here in buffalo
The movement has started
Mite be that the gasket between the pump and the block is worn from getting hot and then cold due to the weather causing it to seperate a little.
IBankMouse
06-13-2020 12:53 PM
