Another damm headlight question
Old Feb 16, 2002 | 02:29 AM
eric2001's Avatar
Has anyone replaced the lenses only to find they are not focused so to speak? When I picked mine up 2 years ago, I found the low beams sucked, and the high beams were aimed perfectly.
After messing around aiming them, I found that the driver side low beam was diffused, not putting out a spot or beam, but a spread pattern that wasn't very bright. The passenger side was fine.
I adjusted the lower 10mm bolt (bottom of lense not the horizontal or vertical adjuster). This adjuster pulls/pushes the bottom of the chrome reflector closer/farther away from the lense. I also bent the low-beam reflector in a little (stuck a mini-mag flashlight in lamp socket and bent the reflector a little at a time) until it appeared to be a tighter beam.
This was a couple hour affair and I had given up then. Does anyone know the proper settings for this (not the horizontal/vertical settings)? I still hate the beam spread, but haven't bothered with adjusting the housing.
Sorry about the long-winded post,
Eric
Old Feb 16, 2002 | 01:16 PM
YBlegal's Avatar
Thats my Girl!!
haha i have the same problem.. just live with it!
Old Feb 16, 2002 | 09:20 PM
Blacura's Avatar
-iii-(
My ride is the same way. It's kind of annoying but maybe hyperwhites will help it out.
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
