AMP Wiring
Old Dec 1, 2003 | 10:13 AM
AlexMN's Avatar
A-CL Member
AMP Wiring
What is the best place to get the power from for a 100 W amp other than directly from the battery. (Getting the power wire from inside the hood to the trunk seems very dificult)
Aren't there any unused fuses in the cabin where I can tap the power from on a 98 3.0? ( I got the remote and the ground from the trunk itself)
Any help is appreciated
Old Dec 1, 2003 | 10:25 AM
Slooo97CL's Avatar
no run a seperate wire with a fuse on it...the only and safest way. unless you are planning on replacing your whole electrical system any time soon
Old Dec 1, 2003 | 10:40 AM
AlexMN's Avatar
A-CL Member
Would it be safe to run the wire through under the car? I bought a pretty thick wire (10 G I think) with fuse? May be even put it in a sleeve while it goes under the car.
Or is there an easy/good spot on the firewall where I could poke the wire through?
Old Dec 1, 2003 | 10:47 AM
proaudio22's Avatar
-S namyaC-
If you really don't want to mess with it, a good shop should do it for you for less than $50.
Old Dec 1, 2003 | 10:55 AM
Slooo97CL's Avatar
if you look above the brake pedal there is a piece of rubber with wire goin in take it out shove it in there...or drill a new hole thru the firewall...id stay away from running a wire under the car...its too exposed..
Old Dec 1, 2003 | 11:36 AM
TeamBlurryCL's Avatar
TEAM BLUR So. CAL
10 gauge is thick? no, that's thin as hell. i wouldn't go any lower than 8 guage. i use 2 and 0 for my car. but i'm running 3 amps
Old Dec 1, 2003 | 11:50 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
i run a 4 guage to the distribution block and 2 - 8 guage out to one amp, the extra is room for expansion later, i did have 2 amps b4 but i blew both of them and then got a new one
and you can run the wire through the firewall hole above on the driver side, well thats at least where i ran mine
Old Dec 1, 2003 | 01:02 PM
jblaze_RENAMED's Avatar
Commander in Chief
I have 0 gauge wire run through that hole, if i can fit that you can fit anything. BTW hiding the 0 gauge under your carpet is like cramming 10 socks in your undies, it's kind of hard not to notice it
Old Dec 1, 2003 | 01:15 PM
fusionnv's Avatar
Gimmie my points Biatch!
Damn I had crazy trouble with my 2 gauge. I was going *@&!^%@&! go into the damn hole.
Old Dec 1, 2003 | 02:52 PM
Leon's Avatar
I feel you on that one, I used 2 gauge but it's the flat wire from crutchfield. and yes 10 guage is very small.
Old Dec 2, 2003 | 03:42 PM
TEAM BLUR So. CAL
my bad i meant 0 and 4 gauge. i have a 4 gauge from the batt in the front to the batt in the back and 0 straight to my 1100d and 2 4's to my 400's
Old Dec 2, 2003 | 04:03 PM
Sideways240sx's Avatar
DAMN.... 1 o's gauge and 2 4 gauges... Do you have a full list of the system with pics? i thought my car was gonna be pretty crazy, but i will only run 1 0 gauge wire to the back to a distribution block.. The distribution block will got to a bat cap, and another distribution block that will feed the amps. I will be running a tantrum 1400 watt d class amp, and a tantrum 400 watt amp. I think 0 gauge will acutally support something like 3000 watts according to phoenix gold. i will be running 2 id max 12's in a slot ported box, and should be good for 150 + db... The car will be mainly sq, but the spl will be there. Interiors i have now are amazing... If any of you guys want new interior speakers and have the money get mb quart q's.. I can turn my alpine cd player up to 35(100 percent volume) and the head unit is going to an interior phoenix gold amp that puts out 530 watts rms. none of my interior speakers distort at all. The mb quart q's in the front get so loud they almost hurt to listen to........ I LOVE THEM... to bad they retail for 1500 and sell for like 1049.... Chris
Old Dec 2, 2003 | 04:20 PM
proaudio22's Avatar
-S namyaC-
I think that's what he's talking about (otherwise is gross overkill). 0/1 ga to a block, then 0/1 still to his larger amp, and 4 to each of the smaller amps.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
