Am I doing this right???
I was trying to advance my ignition timing by a few degrees.... so all I have to do is unbolt the 3 bolts and turn this whole thing counter clockwise right???
http://photos.yahoo.com/bc/cseika02/...src=ph&.view=t
Sorry i don't know how to post pic in the board...
Yes thats correct, but the ECU will reset the timing back to where it wants it since its OBD2.
It can "sense" the timing is off by the cylinder position sensor, and two crank position sensors.
Even with my cam gear (which moves the distributor from the other side of the cam), the timing stays constant at 15 degress btdc with the service connector jumpered, regardless of cam gear setting.
My brothers prelude was the same way. Moved his distributor all the way back on the dyno and NO change.
I just test drove after adjusting the distributor... Feels like the engine is alittle more powerful... i don't know if itz due to the colder weather.. keep in mind that i did this, and drove 2:00am in the morning... I'm driving to work today.. i'll let u guys know if it works or not..
Originally posted by Blacura
5whp?
retarding it helps the high end of the torque curve?
5whp?
I did not pull my engine and put it on an engine dyno to check the gains/tune a cam gear.
