Alternator
Old Nov 15, 2003 | 10:08 PM
MJMeucci's Avatar
Alternator
Today I was driving and then the little battery light came on, since I was close to home, so I turned around and went home. I turned off the car and hooked it up to the trickle charger for a good 7 hours. Went back out tonight and started it and the light was still on and the car made a high pitched whine, and the RPM's went up to like 1800 and slowly dropped down to around like 500-700 (normal for me when I start). I really dont want to drive it because I don't want to get stranded on my way to Acura or anything. What do you guys think?
It is still plugged into the trickle charger. Also I bought and installed a new battery and the light remained on.
I am thinking the alternator, am I way off? What would cause this?
Old Nov 15, 2003 | 10:34 PM
jermz123's Avatar
lol i remember this happend to me i had to push my car downhill for 1/2 a mile.. you should be able to make it to the dealer w/ a new battery..unless its stil bucking even w/ your new battery
Old Nov 15, 2003 | 10:45 PM
MJMeucci's Avatar
its not bucking, it is just making a really high pitched whining noise... I love this car but I have dumped all my mod $$ into repairs. I am not too pleased right now.
Old Nov 16, 2003 | 07:22 AM
EPS CL's Avatar
SSM Accord V6 6 Spd
not to threadjack, but sometimes when it is nighttime and my lights are on, they will fade in and out with the signal lights. in other words, if i signal, the headlights and interior lights fade in and out in the same rythm as the blinkers. could this be the alternator? i remember buying my car that acura said the alternator was a little weak.
Old Nov 17, 2003 | 04:17 AM
DIO 87 Prelude's Avatar
CL Poser AKA Tool
the whine sounds like a slipping belt.
you may want to also clean all connections on the batt and on the alternator...just a little help
Old Nov 17, 2003 | 09:50 AM
okbye2's Avatar
Alternator. think it runs $85 +install
It happened to mine already
Old Nov 17, 2003 | 11:17 AM
Sacramento CL's Avatar
A-CL Member
Tighten your alternator belt. While you're down there, check to belt to make sure it's still in good condition.
Old Nov 17, 2003 | 01:17 PM
97blkura's Avatar
i spend 250 on a 150 amp alternator and thing works amazing.... even with my 1000 watt system the lights dont dim
Old Nov 17, 2003 | 04:50 PM
wilp99's Avatar
the belt is probibaly too loose, and not spinning the alternator fast enough. the wine could also be the alternator bearings going out. so poke your belt with your finger and see if its loose if not get a new alternator.
Old Nov 17, 2003 | 05:26 PM
Hobo's Avatar
Flap.
i had my alternator replaced like 3 months ago,
it was running great but recently when i idle the car makes a repatitive chich chich chich (dont really know how to describe it) sound and the lights dimmed on me once....
anyone have insight... or do i have to make teh dreaded trip to Ack...
thx
Old Nov 20, 2003 | 06:08 AM
2_clean's Avatar
That's your alternator going bad. Mine went out 4 months ago. I had the same high pitched whining noise. It started out very low then got kinda loud, and it sounds like it's coming from somewhere in your dash. I bought a new one from Dave's DC Electric in CA. Paid too much for it though. Just get one from Pep Boys or Advance Auto Parts... cheap with warranty
Old Nov 20, 2003 | 01:47 PM
DeadLeg's Avatar
I miss her...
First my starter went out(carmax fixed for free-warranty) and then my alternator went out(same symptoms) and I paid close to 200 for a new one... haven't had any problems... Oh, and I think my power windows is going next...
P.S. all that was just a warning to other CL's... I now of many that have had starter and alternator replacements... and only a few that have had the power windows replaced.
Old Nov 20, 2003 | 01:57 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
my alternator went out on me once...well actually the battery light and check engine light came on...so the nearest ACURA dealer is about 15 miles away....my damn car didnt even have enough power to do anything! im lucky i make it there! i coudnt use the radio or windows, shit, everytime i tapped the break the needles on the spedo would drop to zero (yes the car was still running...like when i came to a stoplight) then the needles would jump liek crazy, it actually said i was going 120 when actyually i was goin about 45mph..it was crazy...at one time, there wasnt even enough power to push fuel through the pump...the car was in drive and was just revving (like it was in nutural) when i tried to go at a green light...so i sat there revving it and all of the sudden the car kicked in and i pealed out...lol (a civic ricer next to me got a good laugh....i bet i looked soo stupid) so yea..bad stuff...
oh yea, the damn acura dealer charged me like $250 also!!!
Old Nov 20, 2003 | 04:40 PM
lowpost's Avatar
the whine is usually your alternator bearing going out..
Old Nov 23, 2003 | 06:23 AM
cota50's Avatar
7th Gear
The whine is from the alternator. The turn sinal problem was from a pinched wire in the steering column.
Old Nov 24, 2003 | 12:15 AM
hougee's Avatar
kee-master
my alternator started whining back in the summer... and one day... the whine disappeared.. and i thought my car cured itself.. :P hee hee.. newayz... later that day my car won't start ne more.. and that's when i found out that my alternator died completely.. heehee...
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
agupta3224
Sep 22, 2015 08:08 PM
