Adjusting Headlights
Old Jun 1, 2006 | 07:18 PM
yossi's Avatar
I was getting flashed alot at night recently, so on a whim i parked in front of a wall and noticed my left headlight is shines a few inches higher on the wall than the right, whats the proper way to set the height (i.e x feet from a wall, lights should be x inches off ground) and how do i adjust the height of the beam?
Old Jun 1, 2006 | 07:25 PM
SupraManAG's Avatar
One custom CL
goodluck in figuring that out
there are the knobs you turn to adjust them but they do no turn for crap
ive tried on mine numerous times with no avail
Old Jun 1, 2006 | 08:13 PM
zhouz's Avatar
say: zouts
there is a gear you turn with a phillips screwdriver. you jam the screwdriver in and use it as a knob. the instructions should be in the owners manual.
Old Jun 1, 2006 | 09:38 PM
CLean 3.0's Avatar
CLeanest in its CLass
measure the height from the floor to the middle of your headlamp assy. then mark a horizontal line on the wall. then two vertical lines centered with your headlamp assy. again so you have two crosses. then back your car straight back 25 ft. then turn on your headlights. your low beams should be on on the outer lower corners of each cross. hope that helped
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
