AC problem
AC problem
My compressor doesn't come on nor does the ac fan, what could be the problem? I know it's not the compressor because I ran a wire from the compressor directly to the battery and it came on. I checked all the fuses and they're good, the only I can't tell if it's good or not in the "cooling fan relay" which is a black relay under the hood, has anyone else had this problem?
mine was doing the same thing after the swap and i found out it was a pressure switch. Also (sure you already know this) the system wont run if its empty or charged improperly (over/under)
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
