ABS Problem
Turn Signals are good!
ABS Problem
Anyone ever have trouble with their ABS system? My light comes on a few seconds after I start driving, and stays on all the time. Obviously my ABS is not working either. Anyone have similar problems. I checked all the wirring connections under the car, in the engine compartment and at the control module, and they are all fine. Just looking for some input before I head to Acura.
Old School Ridin Clean
when you turn on your car do you hear a noise? if it does your abs pump is broken. THat runs you like 900 dollars.......this happened to me. Of course i just took out the main fuse for the abs system, abs is a luxury and u can brake without it.
If you want to get it fixed then go ahead, but u don't really need it.
hollaaaaa
hollaaaaa
Yeah, ABS is a luxury... but I flat-spotted my brand new (put on today) tires today when some ass hole pulled out in front of me while I was doing 60! Then it was a luxury in need... its not too often that you see an Acura almost sideways in the middle of the road. People need to learn how to drive!
ABS problems are gonna cost some $$$$. I disconnected the fuse on my old Legend when I had this problem... but of course the light still came on so I pulled out the ABS light bulb behind the gauge cluster... problem solved. No more annoying light, but no more ABS either, which I dont really care for.
SidhuSaaB
05-30-2020 12:40 AM
