ABS Light problem!
Old Dec 23, 2006 | 03:26 PM
megaman81's Avatar
ABS Light problem!
Hello people,,
i have 1997 acura 2.2 cl manual.
I got the abs light when the cv boot went bad..and i replaced the cv boot and wiped off the abs sensor with a cloth. The abs light still stays on even after wiping off the sensor from all the cv boot grease. Should i wash the sensor with a damp cloth and some soapy water? If not..
How can i turn that annoying abs light off? Is there a way to disconnect the abs system? I dont care about the abs system and cant afford abs sensors right about now... Please help me out!
Happy holidays!!!
mc
Old Dec 23, 2006 | 04:29 PM
megaman81's Avatar
Where is the ABS module in our cars? I read somewhere taht it will disable the abs light!
any replies apprecieated.
thanks
Old Dec 23, 2006 | 05:02 PM
megaman81's Avatar
checked the codes by jumping the blue connector
got 44 & 48
left and right Rear wheel sensors!
how can both of them go at sme time? Is this possible?
Old Dec 23, 2006 | 08:27 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It's most likely your wheel speed sensor, i've replaced 3 already. The ABS unit is under the hood by the fuse box
Old Dec 24, 2006 | 09:17 AM
TexasHonda's Avatar
Originally Posted by megaman81
Hello people,,
Happy holidays!!!
mc
The ABS wheel sensor should be removed and cleaned, and the rotor on the wheel should also be cleaned. Clean rotor by stuffing rag into sensor hole and turning wheel by hand. This will fix a problem caused by dirt and grease, but wont fix a damaged or faulty sensor. Check ebay or car-part.com for a used part at a reasonable price. Wheel sensors may take a bit of searching w/ local salvage yards to locate.
good luck
mada51589
Jan 9, 2025 04:40 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
brandnewcolony
Sep 12, 2015 10:39 AM
HeloDown
Sep 8, 2015 06:51 PM
Stu2414
Aug 30, 2015 07:30 PM
