ABS light code 1 - Pump motor over run
Old Oct 13, 2004 | 06:32 PM
Chinisimo's Avatar
what does this mean?
i checked the ABS reseivor and it looks empty. could this be it? why would it go empty though? also, is ABS fluid same as brake fluid?
thanks
Old Oct 14, 2004 | 03:21 PM
uiskibum's Avatar
its paid for
I can say that yes the fluid that goes in the ABS system is the same as the fluid you use in the normal brake system (DOT 3 fluid). I can't tell you why its empty or what the code means. You may have a leak somewhere in the system that caused it to drain. Also if it is totally empty you may want to take it to a mechanic and see if you'll need to bleed the system out when you refill it.
Old Oct 14, 2004 | 04:11 PM
Chinisimo's Avatar
i just refilled it and resetted the computer (battery off, ecu fuses (both from inside and under hood) out, ABS fuse out. the light still came on
i guess i'll have to make an appointment w/ acura later
Old Oct 14, 2004 | 09:06 PM
oz.one's Avatar
yeah you deffinately have a leak somewhere. it shouldn't be empty.
mine sprung a whole in the aluminum hydraulic resevour. makes an awful noise when it tries to get pressure.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
kmarqueling
Oct 3, 2015 01:14 AM
NSolace
Sep 3, 2015 08:14 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
