Old Jul 20, 2002 | 01:50 PM
kama's Avatar
7th Gear
NewBie Question:
will the 18's rub on fender or rear arm?
Old Jul 20, 2002 | 03:27 PM
1StGenCL's Avatar
958 & 991
When you upsize your wheels you downsize your tires (lower profile) to keep the same overall diameter as your stock 16s. This means you just have more wheel and less tire so you shouldnt rub unless you have an extreme drop or you decide to put on thicker tires which will throw off your speedo
Old Jul 20, 2002 | 03:42 PM
R1Performance's Avatar
Power of Dreams
Given the correct offset with the wheel, you should be fine.
Old Jul 20, 2002 | 03:51 PM
kama's Avatar
7th Gear
well i was thinking of getting some rims that were 18 x 7.5 with 42mm offset, and some falken 225/40/18. Would I need or be able to add a 1.5" drop to it?
Old Jul 20, 2002 | 04:51 PM
Power of Dreams
That will work without a problem.
Old Jul 20, 2002 | 06:36 PM
kama's Avatar
7th Gear
is there anywhere in Los Angeles someone would recommend checking out? Or have any of you guys had good experiences on ordering tires/wheels online....
Old Jul 20, 2002 | 08:53 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Agreed! That's the size/offset/drop I'm running!
4drviper
Apr 23, 2025 07:13 PM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
