99 cl noisy motor
99 cl noisy motor
I have had my 99. 2.3 Cl for 5years now. engine got noisy at 18k, changed engine (warranty) at 60,000. noisy again at 80,000 , now has 100,000 still noisy at low RPM, performance un affected, anyone else with simular experience?
A-CL Totaled Member
Mine sounds kind of like a small diesel when its cold. A valve alignment has helped a lot in the past. If its really loud I would check for an exhaust leak.
I'm a llama :(
Stylin CL
Originally Posted by cl_jay
how would you check for a exhaust leak
Stylin CL
A-CL Totaled Member
Originally Posted by Epoc
About how much is it for a valve adjustment, i need to get this done soon.
99CL 3.0 Premium
Mine is noiser at 69,000 miles, than when it was new but not overwhelmingly noisy. Its mosly druring cold weather. I probably could use a valve adjustment but I'm a stickler for using the dealer for detailed engine work & I know they will gouge me on the price.
I'm rich biatch!
sounds like valves to me -I noticed you live in Canada, do you drive it hard when the engine is still cold? that can do some serious damage to your valves.
I think the valve adjustment is about $120(U.S.) at the dealer for the 4 cyl about $180 for the 6cyl
noisy cl 2.3
The dealership changed my motor at 60k. they ajusted valves several times change timing belts , idlers you name it. I have over a hundred Kilos on it now . Performs well so i live with it, I will never buy another accura , 4cyl. My co worker has an accord 2.3 no noise problem.
Trailblazer = SUCK
Trailblazer = SUCK
right, Which means it has nothing to do with acura in general. its just a lemon. youl will occasionally have the same problems with lots of other known good cars.
Jamus22
06-11-2023 10:08 AM
xsilverhawkx
09-28-2015 06:51 PM
09-25-2015 06:14 PM
