98 accord knuckles the same as 2.3 cl knuckles ??
Si says "shut the fuk up"
are they they same? i have a looked up the part numbers for the honda and acura parts site but they use a different part numbering system. i kno they are very similar but i need to know if the knuckles are interchangable.
i found a honda and acura site with similar part number systems.
www.acuraautomotiveparts.org
and
www.slhondaparts.com
it seems like all the 97 accord stuff had the same EXACT part numbers as 97 cl stuff
BUT
when i checked 98 accord stuff compared to 98 2.3 cl stuff, part numbers were SLIGHTLY
off....even things like hubs and disc brakes that should be the same have different part
numbers....
and
BUT
numbers....
example: 98 accord hub assembly 44600-S84-A00
98 2.3 cl hub assembly 44600-SY8-A00
but 98 accord and 98 cl have both the same parts number for front disc brakes :45251-S84-A01
im confused..
im confused..
I'm pretty sure that the front knuckles from a 98+ accord would be the same as a 2.3 because they both dont have the hub over rotor design. The 94-97 Accords and the 97 2.2 would be the same...
i was actually looking for 2.3 hubs (honda 98 accord? or acura 98 cl)to swap them with the
crappy 97 CL design. its such an easy swap i decided that ill get those parts from honda
cuz i got a good link there. so i found out that the 98 accord hubs are NOT the same as 98-
99 CL. so i couldnt buy the hubs from honda and that i have to find them at acura or
somewhere else. so then i asked myself "what if i just swapped the whole knuckle from a
98 accord?". but they dont work wont fit. need them from 98-99 2.3 CLs ONLY just to get
the rotor over hub setup. then u can get bigger brakes later on if u wanted too......wow
that was long post. hope its readable ahhahah
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
