97 steering wheel removal help
For Life
Got stuck removing the steering wheel in my 97, I read the entire DIY guide but it is for the 98-99 and I can't figure out how to get the right hand side cruise control buttons off the wheel, so that I can remove the right hand side Torx screx for the air bag. Anyone have any clue how that thing comes off? I've more or less tried everything that I can think of at this point....
picture for reference
http://tinypic.com/view.php?pic=xysk0&s=7
http://tinypic.com/view.php?pic=fduj3q&s=7
http://tinypic.com/view.php?pic=2m5drax&s=7
It's usually on there really well...... try putting small screwdriver under the cover below the set button and above the resume. Pry them away from the buttons then away from the steering wheel.
For Life
finally got it off, cracked it a little in the process, thing does not want to come off at all. got the steering wheel aligned straight now, but still doesnt solve my problem of my car not being able to turn left well. as in my car doesnt make a very tight left hand u-turn but i can turn right very well. seems like i cant turn my steering wheel as far left as i can right??
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If you couldnt turn very far left before the new steering wheels was put on it might be wise to go get an alignment check. If your caster is out enough on your left side it will effect you being able to turn so far. Plus it's always good maintenance to get an alignment lol.
2.2CL owner
