97 CL 2.2S mystery wire/plug
I have a wire that I cannot find anything to plug into it
It runs up alongside the shifter
Here is the plug
Guess behind the lighter and below the stereo
At the why it goes up into the right toward the glove compartment
And it came from this slot here that I'm pointing at on the right side of the gear shift below the ladder
in my manual transmission 97 cl 2.2 on each side of the shifter is a place for something. Plug, device, ??? Under the slot on the passenger side is a wire and I have no idea where it goes. I cannot find any diagram on my specific car that I can read. This started with changing the stereo and removing the center compartments to access the required area.
This is the plug
Routes under stereo
At the Y goes up to the right toward globe compartment
Here is the plug
This is the plug
Routes under stereo
Text in post came out mixed up. Sorry. Please help me identify a wire and pl
Here is the plug
This is the plug
Routes under stereo
Here is the plug
This is the plug
Routes under stereo
OR, one of either #12 or #17 would fill the driver side spot on the second graphic below??
Unfortunately, it appears they are no longer available, which would give them a name, because they are not listed on the OEM vendor website link provided below:
Switch - 1997 Acura CL 2 Door BAS2.2 KA 5MT (acurapartswarehouse.com)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
It's a fog light switch connector. CL's came prewired for the OEM fogs but most did not have that option. That is right where my OEM fog light switch is located on the right side
Heated seat switches on the left side
JMiles_T
12-30-2018 01:24 PM
CJ Majesty
35
12-17-2010 02:44 PM
frankf0k168
10-18-2006 04:01 AM
