3.0 coil wiring
3.0 coil wiring
Could someone please give me the positive (+) and negitive (-) wires in the 3.0 coil wire harness.
I've got a new coil that I'm itching to install.
Thanks!
Thanks!
A-CL Post Whore w/N2O
Re: 3.0 coil wiring
Thanks!
Thanks!
Turn Signals are good!
I tired putting an Accel coil in my bro's car, with no luck... I tried both wirring possibilities with the positive staying the same (the black/yellow wire) and switching the negative between the 2 other wires and I couldnt get the car to start. Now that I think about it though, it should work with the black/yellow wire for positive and a chassis ground. Doing so may screw with the computer though... although it is worth a shot... If you get to it before I do, let me know if it works... I'll try during the day sometime.
SUPRMN84
10-07-2015 09:46 PM
