225/45/17??? Good tire size?
As long as your not superlowered you will not have problems with that size of tire. It's a huge tire though... 225/45. I'm on 215/40/17's and they are just rubberbands on rims, so try to find something in between. I had massive rubbing w/ 225/45, but than again, i have 2 inch clearance on my exhaust piping :\
I use 215/45 and that is the same diameter as stock. Decent profile, not like rubber bands, but with Atlanta potholes, maybe I should have made them meatier. But, if you look at the rear, the control arm sits pretty close to the tire, not much room there.
i just got prokits and some koni yellows on the way, but i was thinkin of gettin the 225/45s also over the 215/45s to suck up some more wheel gap. i think i should just stick with 215/45s when i get my rims. i dont care if 225/45s will work. the ? is what would u guys buy? i havent lowered my car yet so i have no experience cept that stock suspension gots to go.
...but with Atlanta potholes, maybe I should have made them meatier. But, if you look at the rear, the control arm sits pretty close to the tire, not much room there.
...so your speedometer will be off by a bit.
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
