225/40/18 Tire Rubbing! Help?
As you all know, I recently put on 18's with 225/40/18 Kuhmo 712's. But the back tires rub. They are rubbing on that arm that crosses over the back wheel, I think it's a ball joint arm. It only does it when I tweak the back end. (i.e. Turning right into a sloped drive) Is there any solution to this problem?? Can I move that arm or shave it away a little?
I am lowering the car next week with the pro-kit. Will that arm come down with the spring? (I dont think it will) But if it does, it will be sitting on my tire!! As of right now, no lowering done, I can fit my fingers between the tire and that bar.
HELP!
Thanx
HELP!
Thanx
Lowering it won't kae it any worse, but your front will get bad. Sounds like you have a different offset then the rest of us on your wheels. What is yours?
THat bar is the upper control arm. It controls the linearity of the rear wheels keeping them true up and down.
Strange. Something isn't jiving here. If you have a 42mm offset, then why is your car the only one rubbing the tires? I also have 225/40/18's and I had my rims on before I got it dropped, and I never experienced any rubbing whatsoever.
May want to do some investigating into the true offset of those rims you have. Also may want to look at your rear suspension and axles, something may need to be replaced there as well.
Originally posted by 99Black3.0
Chris- what do you mean my front will go bad?? And my recepit from the wheel place for my wheels say 42mm?
Even with the prokit? I plan on keeping the stock struts for awhile
Zonian22
Nov 14, 2015 01:20 PM
rockvilleTL
Sep 19, 2015 04:44 PM
oyayjoe
Sep 12, 2015 04:40 PM
