2.2safc2 install
2.2safc2 install
cant figure out which wiring diagram to use supplied by apexi because your cl2.2 isnt listed?Its [H6A](for the most part)I assume this is correct even though that diagram shows a knock signal wire there when there isnt a wire in that location on the ecu.And i havent found this wire on the line diagram either.But i will check with my friends at the speedshop to back this up.It seems to be working fine,with no problems but apexi has never tested this so goodluck if you damage something.We will see.....the next step is 440cc injectors
turbo)t3/t4 ar.60/.63 turbonetics,garret
intercooler)4"deep*6 1/2"tall*29 1/2"long
i/c pipes)2"charge side,2 1/2" other 6061 aluminum
header)" stainless
downpipe)2 1/2" stainless
wastegate)hks 5lb spring
alot of extras
pics will have to wait till i get my digital cam back,plus my bumper is at a body shop getting repainted,lol.But soon.Its coming together,still under construction.Installed the injectors today but having some problems with the new orings,so its back to honda tomorrow
header)" stainless
alot of extras
injectors are fixed and car runs great
![tv](https://acurazine.com/forums/images/smilies/tv.gif)
HTML Code:
newB
http://racingzone.com
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
