104 Octane
104 Octane
This stuff was on sale and it's advertised to clean your fuel line and intakes so I bought one. (I left it in the car so I'll give the full name later) When I read the directions it states for off road only, well hell, why advertise it as a dailer driver helper and not for off roading. Does anyone have experience with adding additive to your fuel?
Originally Posted by Lajit-CL
It says it does both though it's not made by stp. It's in a funky bottle with a cardboard attatchment. AFFESS had it on sale, I'm ganna use it though I don't want to damage my engine.
Originally Posted by saiko_cl_duck
AAFES( did you mean Army Air Force Exchange Service, unless you're talking something else?).
I have used some octane boosters in the past and they don't seem to cause any problems with the cars that I have used them on...
The one fuel additive that I can actually say worked (it worked and I saw a difference in performance) was the old school 'Dura Lube' Fuel System Treatment...
I don't see that on the shelves anymore but all they do is (claim) to put in additives and detergents that cause cleaner running fuel...
Originally Posted by knothd
All your doing is increasing the octane in your gas from say 91 to 104.
Besides, you don't need to run anything higher than 93 on a stock/bolt-on n/a motor.
I don't know where people get this idea that higher octane gas is cleaner and/or will clean out your engine and/or will give you better performance with a compression ratio that doesn't knock with 87. Also, the oil companies are delighted that people will volunteer to pay more to fill up with 94 when their engines don't need it. There's detergents and antifreeze in all gas, even from off-brand service stations (I'm a chemical engineer)
Seafoam will clean out everything, including the long, black, difficult to clean air intake system. It's also the only way you will be able to get grime out of the system in places you can't reach.
How does a gas additive clean your air intake? They should get sued over some of these claims.. 90% of the additives on the shelf at most stores don't work.
To answer your question, 104 octane is supposed to be for highly modified or race vehicles where even 94 octane isn't enough to prevent pinging. I can't see it being much use unless the engine has drastic mods like a supercharger or a turbo.
gavriil
Feb 4, 2005 11:51 AM
gavriil
Nov 4, 2003 08:52 AM
gregshin
May 20, 2003 12:41 PM
