**** window
#41
Originally Posted by cl_jay
i got up too the 2nd pic except i didnt take out the speaker. i cant seem to find how you get to the regulator. i can see it when i stick my head through that big hole, but i dont know how to take it off.
i put a piece of wood to hold up the window for the meantime. but i want to fix it asap.
Take out these bolts...this what holds the motor. then slide the window down and you see where the two bolts are at that hold the window. take that off. to instal just install it on the way you took it off.
#42
1 Post
so what do you mean by "unscrew the speaker and the handle there are 3 on the outside and 3 more on the inside". do you mean for the whole panel or just for the screws for the handle and speaker? I can only see 3 screws on the handle, and one on the open-door handle. once I unscrew the 3 screws pictured for the close the door handle, does it just pull/pop off?
#43
there are 4 screws for the speaker...as you can see.
the handle has 3 on the outside but once you get the door off you will see i think 3 more. then it will come off. so a total of 6 screws just for the handle.
#44
Insert Sarcasm Here
WOA WOA WOA
you dont have to remove the speaker or the powerwindow controls!!!!!!
remove the bolt inside the handle (there is a cover you'll have to take off)
then remove the bolt behind the lever, and remove the lever.
this one
Undo the harness for the lock
Then just pop all the clips out from around the edges of the panel.
Lift straight up, and pull back.
this one
#46
Insert Sarcasm Here
this is unecessary. You dont need to remove the plastic or the handle. Just take the bolts out from inside of them. You are doing WAY too much work for this. The speaker certianly doesn't need to be removed. There are just two bolts, clips, and harnesses. Just let the door-open hang there. This gives room to lift on the door panel.
#47
Insert Sarcasm Here
When changing the regulator. You must let the window down a little bit and the bolt will line up with a hole. Use the hole for access to that bolt. Use that blue painters tape to hold the window in place so it doesn't fall while you are changing the regulator. That bolt holds the regulator to the window. Then remove these three bolts..
Remove the regulator, put the new one in, replace the three bolts, and bolt the window back to the regulator. DONE
#49
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Smalls
You can remove all the harnesses after the door panel is off, that will save you so much time
#51
hey when i look at my regulator, i see some like metal wires all loose in there. i have not heard anybody mention them. is it going to be hard to place those wires back on that rack thing
#53
you will need a new regulator, all those "wires" are loose because it broke. You not not be able to replace them back on the old regulator
yeah those wires should be tight. if they are loose or bent...you need a new one. When I took mine out..it was a mess the wires where loose and bent like crazy.
#57
1 Post
Originally Posted by hybridnrg
which "clips" are you talking about?
#60
hey ghost, i just pull with my hand. i start where the white arrow is. then i make my way popping each clip up till i get to where the window and panel meet. once you do that the panel will be loose. now you just push it upwards towards the window.
for me it was easier when i took off the two screws holding the door handle in place. those screws are being pointed at by red arrows in the above pic.
you can see them after you take off this black plastic
#61
well when you unscrew all those things on the handles and stuff, how the hell do you pull off the plastic panel?do I just grab the handle and pull, or pry it off with a screwdriver or what?
yeah i still dont know what the fawk you are talking about. take a picture..
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
