Replace Battery indicator came on, then went away . Take seriously ?
Hi guys. I started my MDX this morning after sitting outside all night and saw a "replace battery" come up on the MID and then I drove a minute and it went away. It is 27 degrees here but not excessively(for here ) cold. I just started it again and no message.
Battery was replaced when I bought it certified 8000 miles ago. Would the replace battery light stay on if it really needed replacing ? Is there a TSB on the 2G MDX batteries I am unaware of ?
mrgold35
Can you test the electrical system? It might be a faulty alternator not fully charging the battery or a power drain somewhere running it down when the X is off. I had both problems at different times on my RDX when my battery failed and it wasn't the battery. There is an old saying that "heat kills a battery in summer; but, it doesn't die until winter". A electrical check could save you some time.
mrgold35
I usually get my aftermarket batteries from Interstate. They can test your battery for free to make sure it is not that. I would make sure to drive a around for 10-20 minutes before hand to make sure the battery is fully charged. Don't want a low battery from a power drain effecting the test. I had Acura test my electrical system on my RDX. Unfortunately, both times they said it was the battery on my RDX, changed out the battery, another dead battery a few days later, and then they said it was something else after they tested again. I'm not sure if they did a half A$$ job the first electrical test or the low battery was giving them wrong readings.
This is a common complaint. Do some googling. We usually ignore it. If you do a lot of short trips in very cold weather, your battery does not have a chance to fully recharge and you will get this error message. Now, if your battery is over 4-5 years old you may need a new one. Also, batteries can fail prematurely so it would be prudent to get it load tested by someone you trust.
justnspace (02-13-2015)
mrgold35
Had the same issue this year. Replace the battery with a new AGM battery from advanced auto parts. Cheapest AGM with good reviews(deals you can find online; -$50 and $25 off rebate at the time I purchased it. I believe the OEM battery was only a year old and when I took it to get tested, it tested good. Supposedly it is not covered under warranty since I purchased under CPO and original owner has replaced it once already. OEM battery specs seemed inadequate to me so I didn't fight for another free OEM battery. AGM batteries charge quicker then OEM batteries and have other better benefits. Have not seen that warning since.
note: I was also getting it when it was only cold outside also and once I got my first warning it also popped up with low battery warnings. I even put it on a trickle charge which helped but if I skipped a day without doing this warnings will still come on. I contacted Acura relations and they said the firmware update was done to my car already.
For all of us MDX owners I would recommend this:
Equus Innova 3721 Battery and Charging System Monitor.
It will cost you about $14 at Americas largest retail chain.
I have used these things for years in my MDX and RL due to both cars being notorious for getting through batteries and being on the edge of being adequate. They are permanently plugged in and a quick glance gives you a clue on a daily basis.
I get the replace battery message on my TL every winter when the temp goes below 10*F if the car sits outside. This morning we got the message on the MDX. Both vehicles always start strong and I've yet to replace a battery in either - 2010 MDX and 2012 TL SH-AWD. Tomorrow is supposed to be even colder, so I expect to see it again
mrgold35
I haven't seen the battery light since the firmware updated; but, I still don't trust the OEM battery. When it fails or dies, I want to change to AGM battery.
I did purchased the GB30 Boost from Amazon for about $125. You can charge it using USB, very small, jump vehicles up to 20 times, "idiot proof" electronic circuits, has 2 LED lights, and can recharge any USB device. I've had two OEM batteries fail without warning on my TSX and RDX (still have OEM battery in MDX). I used it on my Mom's 1999 Supercharged Bonneville SSEi and my TSX (overhead TSX dome light comes on randomly and runs down battery). If the vehicle is 100% dead, you have to let it sit for a little bit on the battery after you hit the red exclamation button. It jumped both vehicle with no problems both times. I still keep jumper cables in my vehicles as a back-up (jumper cables also have idiot proof circuit).
technocrat (02-18-2015)
Other symptoms
Before my replace battery warning appeared, I noticed that the steering whel wasn't motoring to it's usual position when I started the car. I figured the cold was causing more resistance than usual and some overzealous sensor was preventing it from pushing through (less you somehow get crushed).
I was wrong. Replacing that battery (Duracell AGM from Sams Club) fixed everything. The low voltage was causing the issue (the cold probably was still playing a role, but it impacted the battery, not he wheel itself).
So, do you have any other symptoms? If so, replace the battery.
Rich and Famous
After a few low voltage warnings ..
The dealer replaced my '11 MDX Advance battery - to my surprise - after my first service in Jan 12 and did not have any issues till yesterday. Yesterday I got "Replace Battery warning".
Since its now 4 years old and they don't last anywhere near the 100 month warranty stamped on it - also I understand that Acura don't honor replacement warranty (##@@%^&*), I just got a replacement from Advance Auto for $100.
The new replacement has 700 CCA and 3 year free replacement (5 year total) vs the Acura 630 CCA and at best questionable warranty.
Will put new battery in today and post what effects are over time ..
Does anyone here use a multi-meter to test ???
If so please respond how best to test your battery.
mrgold35
I ended up replacing my OEM battery that was +5 yrs old after getting a dash cam. I think the battery was already borderline; but, it had enough power to start everyday and I didn't notice. Adding the dash cam dropped the power below borderline (dash cam ran in parking mode drained more power). I also got the replace battery warning a few times; but, it went away after charging the battery.
Went ahead and replaced with an Interstate AGM battery a few months ago and zero issues since.
mada51589
05-03-2022 08:54 PM
