Check Transmission D Blinks
I drive a 2009 Acura MDX. Today I got the Check Transmission Light and the D Started blinking.
When I drive it gives some wierd noises too.
What do i do ?
What do i do ?
Pull the codes... If you have Tech go to the NAV screen > Messages > Diagnostic Info and it will tell you the codes.
If you have aa Base go to an Autozone..
We can diagnose from the codes.
No need to open a second thread in a completely different subforum for the same problem..
If you could tell us what car you drove, year , mileage, that would probably help as well.
Seems that there is an issue with the Solenoid C in the Trans..
How is the fluid looking? any records of maintenance?
Check the ATF Level otherwise this will be a Dealership only Part...
You can either try to clean the solenoid or it is malfunctioning which will mean you have to replace it.
If you go to a private shop try to go to a Transmission Shop, Not a general Mechanic.
Thank you so much for all the information.
Since I am worried to drive a long distance will try once with my nearby Gas Station mechanic first and see if I can get a quote first.
Most of the solutions given on the web goes behind changing the Transmission Fluid will try that first.
If i can drive to the Dealer then will check it out at the Acura Dealer too.
