After replace timing belt cel p0135 o2 sensor heated circuit high and vtm4 and p1399
Old 07-19-2018, 03:35 AM
3rd Gear
civictype-r's Avatar
Hi everyone,I have 2002 acura mdx.188k miles.oil leak between oil pump and the block also oil pan.but the car running fine no problem.so I clean the engine with high pressure water.after clean up I started the engine and back in the garage to remove the timing belt and oil pan to resealed.so I decided to replace the timing belt ,water pump,auto tensioner.timing belt idler.cam seal,crank seal,and oil filter housing gasket.then everything finish.I started the engine got cel p0135 o2 sensor bank 1 sensor 1 heated circuit high and vtm4.the engine like misfire.I try to rev it but got to 2500 rpm and stay at 2500. no higher even I floor the gas pedal.then I release the gas pedal then the engine stall.I replace o2 sensor.now more code p0135 but it throw code p1399.new ngk spark plugs.coil ok.but now it rev up to 4500 rpm no problem,but the engine still sound like misfire.the timing mark look ok.don't know it because the timing belt cause the problem or something else cause it.have anyone runner into this problem before or know how to fix it please help me out.thanks in advance.
Old 07-19-2018, 10:11 AM
97'CL2.2's Avatar
sounds like you forced some water into an electrical connector with the power washer, check the crank sensor. to be safe id clean all the connectors in the area with some electrical component cleaner and clear the codes.
Old 07-19-2018, 02:01 PM
3rd Gear
can you guy see if my camshaft mark look ok.the crankshaft timing sprocket mark is match the oil pump mark. But the rear camshaft a little off.i can't put exactly the camshaft teeth straight with the mark on the back plate.is this cause to misfire code p1399 and p0135 o2 sensor.
Rear cam
Front cam
mad_x
1/2G MDX (2001-2013)
02-05-2015 12:07 PM
Keyzmama
1G TSX Problems & Fixes
03-10-2014 03:25 PM
smartypants
02-19-2012 01:29 PM
dom
05-04-2010 02:57 PM
CometVR4
08-04-2009 04:38 PM
Quick Reply: After replace timing belt cel p0135 o2 sensor heated circuit high and vtm4 and p1399
