What A/C setting should I do?
If i dont want to use to the compressor (saving gas), and just want the outside air temperature
I dont want to open the windows because it gets loud, and i dont know what setting I want so that it doesnt get stale and stuff inside.
what setting should I set everything to?
if it matters i have the touring model
Stay Out Of the Left Lane
Received 1,241 Likes
Assuming you hit the Auto button on the climate control, (which allows the compressor to cycle on and off as needed), when you start your X, simply set the temperature to whatever you want and then just hit the AC button. Hitting the AC button takes the climate control out of the Auto mode and turns the AC off (no compressor). The AC button is a toggle of off and on.
Hope this helps -
Hope this helps -
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
