Stuck on park, vsa, sh-awd, abs after battery change!
Old May 15, 2016 | 06:36 PM
MrOrtiZx's Avatar
3rd Gear
Angry Stuck on park, vsa, sh-awd, abs after battery change!
After I change the battery I have all this lights coming on. Most likely what could be causing this issue? Please help.
Old May 15, 2016 | 06:43 PM
Disconnect the negative terminal to the battery and wait a minute to five, then reconnect battery.
Most likely nothing is wrong, but clear the codes by disconnecting battery then see if they come back
Old May 16, 2016 | 01:15 PM
MrOrtiZx's Avatar
3rd Gear
Thanks I will try this today.
Old May 16, 2016 | 06:43 PM
MrOrtiZx's Avatar
3rd Gear
I did and driver around for a little bit and I am having the same problem. Any Suggestion?
Old May 16, 2016 | 07:13 PM
Could be a bad battery or bad alternator leading to irregular voltage spikes and it's throwing random lights
Army
4G TL Problems & Fixes
Apr 28, 2021 08:14 PM
