seat heater replacement help
5th Gear
We have a 2002 MDX and the drivers seat heater does not work. The back heater does work though. Does anyone know how to replace the seat heater?
Moderator Alumnus
You'll definitely have to take the seat out and remove the leather covering. I think I saw a thread about someone doing this on a TL, I'll see if I can find it.
5th Gear
Does anyone know if fixing the broken wires on the factory heater is a long term fix? If not there is an aftermarket heater they claim to be better than factory. (Everyone says their product is best.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
5th Gear
Here check this out, it's for a TL but it may help.
http://joshsworld.com/cars/acura-tl-seat-heater-fix/
I'd always go factory,![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
I go with factory parts unless someone knows of a better part.
I was hoping someone knew if fixing the broken factory wires is a long term fix.
Moderator Alumnus
The broken wires for the heated seat? If you do it correctly with a good soldering job I don't see why not.
rockyboy
12-06-2022 02:29 PM
asahrts
09-04-2015 05:55 PM
