Replacing coolant?
Old Jan 26, 2009 | 02:14 AM
Mr.Speed's Avatar
Replacing coolant?
Does anyone have the step by step on how to drain and replace the coolant in my MDX?
It is a 2006 MDX. I would also like to put a block heater in it as well and was wondering if anyone knows the location of the plug, has a diagram and torque specs for tightening the block heater?
And last i would like to get a manual for this vehicle Haynes does not have on out for this year any suggestions on where to get a service manual?
thanks
Old Jan 26, 2009 | 07:31 AM
FiftyFive's Avatar
Moderator Alumnus
Replacing coolant is pretty much the same in every car. Check out the following link:
http://www.ehow.com/how_4530501_replace-coolant.html
If you google you can find Service Manuals for the 2006 Acura MDX.
Old Jan 26, 2009 | 11:11 AM
Mr.Speed's Avatar
So?
Step
Wait until the coolant mixture has drained from the system. If your engine block is equipped with a cooling drain plug or bleed screw, place the drain pan underneath the plug and remove it. Does the MDX have this?
Step
And does anyone know where the Block heater plug is?
thx
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
01CLOwner
Oct 9, 2015 01:07 PM
ghuns
Sep 16, 2015 04:26 PM
