Relay switch
Old Mar 30, 2019 | 05:36 PM
Melissa Caron's Avatar
Relay switch
Hi everyone, am looking for some help please.
I am looking for the location of my relay switch in my 2003 mdx. My At temp light is on. We've trouble shotted because our rad fans won't come on. We direct wired from the battery. They come on. We checked the fuses they are all good. So next step is relay switch and or sensor. I'm getting really frustrated because I can't find it. lol hopefully someone can help me out. Many thanks in advance
Old Apr 21, 2019 | 10:49 AM
AcuraMDX.MN's Avatar
4th Gear
Melissa, based on the details, it sounds like it could be a temperature sensor.
The temperature sensor determines when the radiator fan comes on by reading the cooling system temperature. If the sensor isn’t working, your fan won’t come on because it won’t know that the temperature is hot enough to require activation, which can frequently lead to overheating. The sensor is usually located in the car thermostat cover. To check it, disconnect the wires from the sensor and touch them together. If this starts the fan, the sensor is faulty and will need to be replaced. Check your service manual to make sure exactly where the temperature sensor is on your car.
https://www.doityourself.com/stry/5-...r-fan-problems
zmwang
May 18, 2025 03:36 PM
JIGS
Oct 20, 2023 04:19 PM
honda1405
Jun 7, 2017 04:10 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
SHaFT7
Jul 2, 2012 06:11 PM
