Rear Wheel Alignments
Rich and Famous
A week ago I hit a rock in Taos NM while mountain driving.
Thought it was a snow clog that falls from other cars for the 2 seconds I saw it.
But no it was a real just rock that apparently just fell and car in front missed.
It went right thru the rim and had to order both OEM tire and rim.
I had them do an alignment also .. thinking for sure it was messed up.
But SURPRISE .. the front passenger tire where I busted over the rock had great alignment and left rear which never hit anything from when I took delivery with 7 miles was slightly out of spec.
What kind of numbers have you seen on your alignments ??
I am thinking that my left rear was out of spec from the factory.
FWIW - Taos Tire Factory said a $119 plate would be required to align rear .. but it was so slightly out of spec that really it was not required.
Acura_Dude (01-08-2015)
mrgold35
Too bad you didn't say anything while in NM, I have 3 OEM adv rims sitting in my garage collecting dust in Albuquerque. I used one for a full size spare when I upgrade my rims to aftermarket. I was just in Austin last July and ate at Noble Sandwich and and Round Rock BBQ and they were some good eats!
This was the from the last Alignment I had done at Firestone. I keep forgetting to ask them if the specs are different with the Advance model compared to the base/tech MDXs (ADS, larger RSB, extra vehicle weight). I talked to my Acura service manager and he said not much you can do other than rotate your tires because of the rear alignment issues. I haven't notice any unusually wear on my tires and I just cross-rotated a few weeks ago. I've found some rear camber kits online; but, they only seem to be for the base/tech models only.
![Name: 11MDXAlignment_zps5871373a.jpg
Size: 1.72 MB](https://acurazine.com/forums/attachments/1-2g-mdx-2001-2013-166/73526d1501440543-rear-wheel-alignments-11mdxalignment_zps5871373a.jpg)
mrgold35
Your specs look a touch better than mine. I had the alignment done over the summer at firestone; but, I had to take my car in twice to Acura after that for front endlink replacement and replacement of front ADS struts. I didn't get a spec sheet on the alignment since it was all warranty work. The MDX drove/felt the same before/after the ADS work (I guess everything was still in specs). The next time I'm in for a service at Acura, I will ask them if the alignment specs are different for a base/tech MDX compared to an Advance model. I don't want Firestone using the wrong specs, if they are different, with my lifetime alignment warranty.
Rich and Famous
I think you will get differ numbers at differ shops.
Don't really think there is a true accuracy standard that everyone uses.
Perhaps the best method is tire wear.
Did you even try to get full size 19 inch in your under side wheel well ?
I really dont like those space savers.
Noble Pig ..
Noble Pig ..
mrgold35
I have the OEM trailer hitch and the rim/tire fit perfectly under the X. The hitch helps hid the tire a little. The only issue is I have to keep 2 different types of lug nuts because of my aftermarket rims. I also purchased a torque wrench to do the 94lb-ft per lug. I figured if I get a flat, it will be +300 miles out of town. It took about week to get my 20" Conti DWS tires in and I figured I don't want to be on a space saver that long or that far out of town.
Noble Pig Sandwich... The pizza and beer joint next to Noble Pig was really good also.
![Name: image3_zps70f0451e.jpeg
Size: 924.0 KB](https://acurazine.com/forums/attachments/1-2g-mdx-2001-2013-166/73470d1501440363-rear-wheel-alignments-image3_zps70f0451e.jpeg)
Acura Technician
How many miles on this car? a weak rear strut is usually the cause for the camber being slightly out.
SPC 09+ Honda Pilot 07+ Acura MDX Rear Camber Arm Kit - Import Auto Performance
They verified with SPC that it also worked for the advanced model with ADS. Said it had an extra part. Not sure what the part is though. I may get it and put on in the summer but not right now since it too cold out here.
mrgold35
I have the same issue with my RDX (Eibach springs) and TSX (A-spec suspension) with negative camber in the rear. I've noticed I get a touch more tire wear on the outer edge on the front driver compared to the rear driver tire. I know the extra weight and physic is causing more wear on the front/driver tire; but, I think the negative camber might be helping with less wear on the rear outer edge a little bit.
Rich and Famous
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
