Really weird noise coming from engine
Old Nov 13, 2023 | 11:52 AM
dlwnfotjav's Avatar
There's a really weird clonky sound at idle, not very steady either. It goes away after revving but then the engine starts ticking really loud and that's probably a separate issue. It's got 140k and the timing belt kit (Gates) was done about 2 years ago at 129k.
Any help would be greatly appreciated, thanks
Old Nov 13, 2023 | 02:28 PM
deepa1600's Avatar
I think you should remove the drive belt and start it. If it goes away then it's one of the bearings, if it doesn't then remove the timing covers and start it. It could be your timing belt tensioner failing. Your engine itself sounds okay, it sounds like a loose bolt rattling. Also pay attention to drive belt tensioner while it's running, it could be that as well.
Old Nov 16, 2023 | 01:33 PM
dlwnfotjav's Avatar
I took off the accessory belt and timing covers and ran it. Video
However it looks fine. I put it all back together and it sounds almost like it could be coming from the rear of the engine facing the firewall. Any other ideas?
Old Nov 16, 2023 | 05:53 PM
DundukovEM's Avatar
Monitor your battery level (plug-in the charger between runs) and buy a mechanic's stethoscope. Place it VERY CAREFULLY around the different NON-ROTATING points of the engine and determine the loudest point of this sound. Then check the surrounding parts for damage.
Amazon Amazon
Old Nov 17, 2023 | 12:51 AM
whitetiger5's Avatar
Sounds like the adjuster pulley bearings are bad.
Old Dec 30, 2024 | 07:57 AM
wzamrine1's Avatar
did you find out what this was? sounds similar to the noise my tl is making
Thebigboss
4G TL Problems & Fixes
Sep 24, 2021 02:02 AM
Ivan Santana
May 24, 2021 06:04 PM
ThePianoMan
Aug 14, 2014 07:14 AM
SammyCSX
Aug 23, 2011 04:06 PM
Black TL
Dec 13, 2000 12:35 AM
