po401
Old 12-05-2008, 06:42 PM
gmarllc's Avatar
po401
I have a 2002 Acura MDX with a 3.5L engine. I have a code PO 401, insufficient EGR flow. I have 132,000 miles. What can I check?
Old 12-05-2008, 10:35 PM
formula1's Avatar
Your EGR port is probably clogged. You need to clean your intake manifold. There is big writups in the TL 2gen forum on this site. Pretty sure there is a DIY laid out. Just search Seafoam and there should be lots of threads on it. It's a common problem with our cars. Hopefully this helps. I took my intake manifold apart and really cleaned it and then i run seafoam in the gas and also run it thru the vaacum port about every 3000 miles. Thanks F1
Old 12-05-2008, 10:50 PM
akord 97's Avatar
EGR valve or EGR ports.
Old 01-13-2009, 09:57 PM
DasTeknoViking's Avatar
EGR ports have to be cleaned. Its a bit different from a TL/CL. Those have a different intake manifold design from that of the MDX.
There are not parts that have to be replaced actually.... you can clean the plenum cover gasket where the carbon deposits collect.
Let me know if you need any help.
turbogor
01-21-2016 04:45 PM
natesezgoblue
02-08-2013 05:14 AM
HerTL
1G TL Problems & Fixes
11-12-2011 04:01 PM
freebieman
02-22-2011 05:57 PM
jfarabaugh
01-26-2010 09:45 PM
Quick Reply: po401
