Oil Change
Old Dec 8, 2023 | 04:18 PM
jhammermil2008's Avatar
3rd Gear
Oil Change
I am trying to figure out how to change the oil on my 2008 Acura MDX. Thanks for your help.
Old Jan 22, 2024 | 03:49 PM
BigDog4All's Avatar
Here you go.....Good luck.
Old Jan 22, 2024 | 04:45 PM
Pair of TLs's Avatar
Wow...no need to replace the drain bolt washer like on the 3G TLs?
Next question: What do I do with the used oil?
Old Jan 22, 2024 | 05:34 PM
That's just lazy on them.. definitely should always replace the crush washer..
Old Jan 24, 2024 | 08:57 AM
BigDog4All's Avatar
Ditto.....they most times come with oil filter. I ordered a dozen oil filters about a year or so ago, and the oil drain washers came with the oil filters. But YES, always change the oil drain washer, each an every time. You can also pick the oil drain washers at the dealer. Get a bunch, you can always use the.
vindroid
Dec 18, 2025 02:11 PM
jimmy007
Sep 12, 2005 11:26 AM
delicate483
1G TL (1996-1998)
Feb 24, 2005 12:01 AM
rzwill2003
Mar 2, 2004 09:06 PM
